How do I align components on a PCB?
I have a component that I want aligned to another component I have locked:
After clicking the align horizontal centers it looks like this:
The lower component has moved slightly, but doesn't appear to be centered. If I hit the center alignment button several times, the lower component moves a little bit each time until eventually they are aligned.
I then tried aligning the left edges and the bottom component did not move at all:
I then used the align to right edges, and the bottom component aligned as expected:
It seems like the align centers tried to split the difference but couldn't move the top component because it is locked so it only moved part of the way. The align left tried to move the top component only but couldn't because it is locked. The align right moved only the bottom component so the components aligned. The problem I'm having is that I am not discovering that my components are misaligned until after layout because on the PCB they are not so close to one another:
It wasn't until I exported the PCB and edited it in Eagle and then used the left alignment which did what I expected.
What is going on here? The "Align" tool isn't working like it did in Eagle, or similar to any other PCB tool I've used. I've got a bunch of layout to re-do and I'd like to use the tool properly.
