Help to fix Solder Mask on custom Footprint and Trace Routing
edneeves
edneeves
I have a PCB I am creating with wedges that are tracks for a potentiometer wiper. I'm slowing figuring out how to use F360 and have it pretty much where I need it, bar 2 issues:
1. The solder mask I am creating for the copper pour doesn't seem to be removing the mask on the 3d model
2. The trace routing is taking a weird path and I cannot figure out why or how to fix
When looking at the 3D model, I can see the SMD pad seems to be sitting on top of the copper pour I have made. Not sure if thats why I am having issues with my solder mask?
My process for creating the copper wedge is:
1. Create a polygon on the footprint
2. Drop a SMD pad at one end
3. Add a solder mask polygon (I am using the exact same shape as the polygon on the footprint)
edneeves
I solved the trace issue. I just had to redo the traces. Clearly it was changing the trace after I had updated the footprint for the section that was new and keeping the old trace.
edneeves
After a lot of playing around I have it sorted. I didn't really do anything different but I kept playing with it and now its showing as expected.
Pieter.Jan.Van.de.Maele
Great to hear! There still is a few things here that are interesting for us to investigate and we will take a look at them.
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
