HELP NEEDED! Routing: big crossbar that blocks me from where to route
zhl101
zhl101
I'm recently setting up a very simple board to test one of the manufacturer's minimum mechanical requirements. The idea is to route an array of pads in sub-mm scale. To do this, I've made sure to disable relevant DRC and used "ignore violators". However, while routing, there is this big green crossbar on my way that blocks where I want to traces to go. I understand that the crossbar is to visually provide a reference during routing, but it's even bigger than my array and there's no way I can bypass that and route. How can I disable this feature?
Thank you so much in advance!!
jorge_garcia
Hi @zhl101,
I hope you're doing well. That crosshair pops up when there is a layer transition without a via. You may have to ripup a trace nearby to get it to disappear. If you need to be able to just see you can turn off the Unrouted layer and that should hide the X.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
