Fusion Electronics - UX/UI improvement
Dear Fusion team, I have found the UX and UI in many cases inconvenient and strange. Just some examples.
1. There are no "underlined" menu commands in Fusion. In some other software, you can press TOC for Menu command Tools » Component Placement » Reposition Selected Components. It is very fast way to do some routine operations without extra movement and clicking by mouse buttons. In Fusion looks like it is not possible, because all commands are in ribbons, or can be started from command line.
2. It is not possible (or I just do not know how to do this) to assign the shortcuts for switching to Panels. E.g., I want to group change some components' parameters. I need to do it via Inspector. I need to select only components - panel "Selection components" (keyboard shortcut???), Click only on Component, then - selecting components, then panel Inspector (keyboard shortcut???), change there what I want. Then go to panel "Selection components" (keyboard shortcut???), Click on Airwire, click with Shift on Wire... Why Ctrl+A is not used here, or at least some button like "select all types"??? All these sub-tasks can't be performed via keyboard only. It is annoying...
3. Very poor functionalities in crucial modes. Let's discuss routing, or component placement. During routing I can only use Left-Click, double-click, ctrl+right click, space, 4 and enter commands. How can I change the wire width - only by routing panel! In this case, I need to drag my mouse pointer (and trace!) to the right corner of the screen, depending on "push violations" even with pushing by my trace other traces, where I can select required trace width... No any way to select pre-defined width from shortcuts or right-click menu. It looks like context menu is not existing at all in Fusion Electronics!
4. Limitations to assign a keyboard shortcuts for some commands/modes. It was already discussed here.
I suspect, some of these limitations are from "breeding of Eagle with other software", but anyway, now it is not on the level of competitors. Sure, MCAD-ECAD binding is very promising, but current realization is not far away from Beta-version. And how many years already passed after the first release - 10 years or more, I suspect? From my personal point of view, the UX is crucial, because if the user found the using of software not so efficient, he will try to use alternatives (except cases when he/she needs to use Electronics part only in very-very simple cases).
Dear users, are you also struggling from UX? Can you share your experience, may be I just have missed some hidden gems, and it looks much better than I have described above?
The question to Fusion Team is following. Can we expect, or, more general, is it possible to see in near future some improvements on UX/UI for Fusion Electronics, or "it is not possible because of limitation of the integration possibilities of Eagle with our Fusion engine"?
