Fusion Electronics crashing everytime saving a design!
HouseOfMollari
Message 1 of 10
HouseOfMollari
For 2 or 3 weeks now, maybe longer, Fusion360 - Electronics is crashing everytime I save my modifications in PCB-mode. I submitted error reports everytime.
After restarting F360 the new data is present. Something is happening, when fusion has saved everything.
Is that a known issue?
Replies (9)
Message 2 of 10
jorge_garcia
Hello @HouseOfMollari
Welcome to the forum!! This is really concerning. Let me ask you if you try different designs do you still get the crash. Maybe it's something specific to this board, that's my initial hunch.
If other boards work, would you be willing to share this file with us so that we can review what might be going on?
Thank you in advanced.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 10
HouseOfMollari
Thanks for your answer.
You are right. It seems to be only a specific project/file.
I exported all files to EAGLE 9.x and Fusion Archive, created new projects and reimported everything. Saving then works (EAGLE and Fusion Archive based).
If you want to check the original project, I would like to add you to my project, since exporting/importing data will correct what ever issue is in the original files.
Message 4 of 10
panpan_fan
Hi @HouseOfMollari
I hope you are doing well!
From your description, I guess you meet the save crash when you save the Electronic files and check the Milestone check box. It is a known issue and will be fixed in the next release.
Before we release the fix for it, please not check the checkbox to save files if there is no need to save the electronics files as milestone.
 If you need to save the electronics files as milestone, please try below workaround:
1. Save the electronic files without checking the milestone check box
2. Close all electronic files
3. In the data panel, choose the file you want, right click on it, choose Create Milestone
4. When the Milestone is created successfully, you can reopen the electronic files and continue to finish your work
Please have a try, thanks!
Panpan Fan
Message 5 of 10
HouseOfMollari
I created a milestone several weeks ago by checking that checkbox. I don´t now, wether my issue persists since then.
Now I created a milestone as you mentioned, but that does not solve the issue, neither project-file only nor every file.
Creating a new project file only and linking schematics and pcb to keep their history does not fix the issue too.
Message 6 of 10
panpan_fan
Hi @HouseOfMollari
Thanks for your feedback! It seems that it still can't work well when the files already have the milestone.
Would you mind createing a new Electronic Design and referrence a copy of the schematic and 2d PCB to have a try?
For the new Electronic Design, do not create a milestone before the fix release.
I hope it can help you to continue your work.
Sorry for the inconveniences.
Panpan Fan
Message 7 of 10
HouseOfMollari
I did something similar already. Saving works then, but history is lost in this case. If someone requires the history, a backup must be held at some place.
I do not need the history, so I can work ahead again.
So that´s all a workaround...
Message 8 of 10
panpan_fan
Hi @HouseOfMollari
When you do the workaround, you will have a new version 1 schematic and 2d PCB.
You can still keep those crash files. They should work welll when we release the fix for it.
I will keep you updated when we release the fix for it.
Panpan Fan
Message 9 of 10
panpan_fan
Hi @HouseOfMollari
Today we release Fusion 360 V2.0.10440, and the crash issue should have been fixed.
Panpan Fan
Message 10 of 10
HouseOfMollari
Yes, the current release fixed that issue.
Thanks a lot
