Fusion 360 (Read only Error)
asprakash83
asprakash83
When I try to edit this file, it can't be able to save, shows read only mentioned in the pic even through i have subscribed.
jorge_garcia
Hi @asprakash83,
I hope you're doing well. This happens because it seems there is a newer version of the file available, you can see on the top left that you have the warning yellow triangle.  You can do a File > Save As Latest to make it the latest version of the file. I figure that's what you are trying to do.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
