Fusion 360 doesn't remember workspace layout
jeremiahrose
jeremiahrose
Hi there
Just wanted to report a UI annoyance that makes Fusion 360 Electronics more frustrating and clankier than it needs to be.
Whenever I open an electronics library, schematic or board layout, I have to manually close the "Inspector" and "Content manager" panes on the right and left sides of the screen. These are so huge that the space remaining for the actual library/schematic/board is less than 1/3 of my available screen size. If the data panel is open, it's less than a quarter.
When I re-open Fusion at a later date, it has forgotten my workspace meaning I have to reset it every single time.
Perhaps this issue affects me more than others, as I'm on a high-DPI monitor which means everything is the wrong size layout wise. 😞
christopher2KLSVU
Hi, today I started similar topic. I missed yours. i have same experience.
https://forums.autodesk.com/t5/fusion-360-electronics/24-inch-display-but-working-expierience-is-lik...
yiqiu.han
Hi, @jeremiahrose @christopher2KLSVU
Would you please try to hide Design manager, Inspector, and Selection filter from the file menu? The layout can be remembered even if you restart Fusion.
Hope that helps~
-Yiqiu
christopher2KLSVU
This works for me thank you
