Found a "bug" when editing PCB outlines. Can't select objects.
mad.macs
mad.macs
I created a bunch of circles on my 3D board sketch today. When I went to edit the board and select the holes it wouldn't let me select anything. During the sketching of the holes I changed my selection filter to all but sketch geometry to clean things up. This setting carries into the board editor for some reason, so I spent 5 minutes or so figuring out what was going on. It would seem that when editing board edit mode the selection set should revert to select all.
jorge_garcia
Hello @mad.macs,
I hope you're doing well. That's interesting, as far as I know there is no interaction between the filters of the 2 editors. Is there any chance the selection filter was adjusted before pushing to 3D PCB? The Selection filter remembers it's state during a session so that could possibly explain it.
If you can provide some images of the workflow or a screen recording that could helps use diagnose this.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
