Footprint doesn't match imported libraries in PCB view
w_lukas_cepovic
Observer Observer
w_lukas_cepovic
Observer
Observer
I'm trying to connect a USB type-c connector and when going into PCB view the footprint doesn't match the one from the imported library. This is the one I get:
And this is how it is supposed to look like:
The above picture is taken from the fusion 360 library editor without me doing anything so the library is imported fine I guess. I have tried to change the design rule check in many ways. making the min Drill size 0.01 mm and changing the annular ring options to no avail. If you have any thoughts on what to do to fix this I would greatly appreciate it.
P.S. I have encountered this issue with other footprints which have vias as well.
jorge_garcia
Hi @w_lukas_cepovic,
I hope you're doing well. You are getting bit by the annular ring(restring) settings, we are working on making this more obvious. For the full description see this article here:
https://www.autodesk.com/products/fusion-360/blog/what-you-didnt-know-about-eagle-restring/
Basically, you have to adjust the annular ring settings so that the diameters you specified win out.
Let me know if there's anything else I can do for you.
Best Regards,
For a full break
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
