Font size?
Font size?
nnovotney
Font size?
nnovotney
Why is the part name almost unreadable?  It should be AT LEAST as big as the pin number!!!  This about the most important  thing when looking for a part!  How do you see a LIST of the part numbers in this lib? Why is it not in readable black, instead of a washed out  light gray??   Don't want to scroll through 100 barely readable images
Radwan-Almsora
This issue stems from the library display defaults in Autodesk Fusion. Frustrations with washed-out light gray text, microscopic part names, and forced image-heavy browsing can be resolved by switching to a text-based list view and editing your display preferences.
don't forget to click the Accept Solution button and leave a < like !
nnovotney
switching to a text-based list view   What are you referring to??? Is there a list view button to show everything as a list with the component names?   I only see  left-right arrows & it shows components one at a time
l47136036
Observer
Observer
I’m wondering the same thing. I don’t see any list-view option in the library browser—just the left/right arrows that show one component at a time. If there’s a setting or button to switch to a searchable text list with readable component names, could you point out where it is?
sungyohaan2033
Community Visitor
Community Visitor
I am new here and I was having the same issue anyone knows a best solution.
jorge_garcia
Hello Everyone,
I hope you're doing well. I will take this to the developers for review, there is no mechanism currently to adjust those font sizes but I will bring it up to them.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Closed-Loop-Bot
Thanks for bringing this to our attention. We're investigating the issue, and you can reference ticket FUS-255678 when communicating with Autodesk to find out more. Once the status of this will change, there will be a follow-up forum post made.
