Export DWG/PDF to tNames/bNames, Silkscreen and Pads
Kristey
Kristey
Any ULP to create a file with a DWG or a PDF with some layer informations?
I design the schematic and the board and we have another team to build the PCB+components.
They always ask for a document so that can print and identify the components and polarities.
What I do now is choose the layers I want and print manually.
But isn't there a way to ask this question with any UPL?
Best Regards
jorge_garcia
Hi @Kristey ,
I hope you're doing well. The procedure you've been following is basically the best way to do it. One thing you can do to speed up the workflow is create a layer set that only contains those layers. That way you can quickly switch to the assembly drawing view.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
