Exclude parts from BOM - deal with module variants
llemorvan
Observer Observer
llemorvan
Observer
Observer
Hello, I am new to Fusion 360.
I would like to remove parts like test points from my BOM. I tried to use variants as I've seen in other posts, however my design is composed of different module sheets.
So I see that I can define an assembly variant for each separated module, but it does not seem to have an impact on the general BOM, and I don't understand how to apply these module variants to main assembly variants.
Thank you very much in advance!
jorge_garcia
Hello @llemorvan,
I hope you're doing well. The built in BOM ULP can handle a top level assembly but it won't handle module variants correctly.
For now, the best solution is to export the BOM take it into a spreadsheet editor and then remove whatever rows are not needed.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
m.neujahr_at_moe
Hello @llemorvan ,
you cal also use the ULP "bom.ulp" to switch between variants:
And then switch between your variants:
Hint:
  • You can edit the ULP to your needs, for example ignore testpoints, add MPN, ...
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
m.neujahr_at_moe
Hello @llemorvan ,
you can edit the original "bom.ulp".
If you want to exclude special parts (testpoints, ..) you can ignore them by editing the file:
  schematic (SCH)
    SCH.allparts (P)
      if (P.device.package)
        if ((P.populate) && (!(strsub(P.name, 0, 2) == "TP")) && (!(P.value == "entf.")))
          PartName[NumParts] = P.name;
          PartValue[NumParts] = P.value;
Here all parts that are not populated ("entf.") and all testpoints ("TP") are not collected in the BOM
