Error message in 3D PCB tab and misplaced components, possible bug in latest ?
xpuipc
xpuipc
since the last update to 2.0.8335 i get this warning:
...every time after
1. pushing 2D PCB to 3D pcb...in the timeline you can then see this:
The pcb looks fine here but when i
2. use this pcb in my enclosure (the board is referenced there)
most of the components are not placed correctly (two are correct):
with the previous version this workflow worked fine..
Anything i can do here ?
Thank you
Torsten
panpan_fan
Hi @xpuipc
I hope you are doing well.
I see your description of the Issue and I think it may be a bug  (package components aren't included in the joint group)that has been fixed in the Fusion V2.0.8335. But the 2d/3d PCB which you have created in old Fusion version may still have the issue.  Can you try to add or delete a part in the schematic and Switch to 2d PCB, View 3D PCB to check if it will solved the problem?
Best Regards
Panpan Fan
xpuipc
@panpan_fan 😀...did it...now works...😀
Thank you for your help
Torsten
panpan_fan
Hi @xpuipc
I am glad it works. Thanks for posting the issue in the Fusion Forum. If you have any issues when using Fusion 360, please let us know, thanks!
Best Regards
Panpan Fan
