Up until recently I had only been using Single-User Storage and didn't have a Team. Nothing showed in the "Teams you are a member of" in the upper left corner of Fusion. Then later I wanted to use the new Configurations feature (which requires a Team), and created a Team and transitioned all my projects to that Team in the process. Now, when I create a schematic with my Team active and go to the Library Manager and filter to only show Fusion Team libraries, then my libraries are not visible. If I switch back to Single-User Storage, then my libraries are visible.
What's the best procedure to get my Team libraries that I had (or have) in Single-User Storage to my newly created Team?
I tried importing a library from the Fusion Project folder where I have stored it, but that created a locally stored library.
Edit:
If I go to the Fusion web portal, I apparently have two Teams. The one showed as Default is the one I created. Are my libraries stuck in the other one, somehow tied to the Single-User Storage?
I only have one Team visible in Fusion:
Edit again: Apparently the "myhub" Team is Single-User Storage. The initial question remains: What's the recommended or easiest way to get my electronics libraries that I originally created in Single-User Storage moved to my new "Mutli-User" Team? The Library "projects" are in the new Multi-User storage, but are not shown by the Library Manager.
