Editing board shape in 3D view breaks the 2D layout
aeies
aeies
I originally had a perfect circle as my outer dimension, but I needed a small slot so I entered the 3D workspace and edited the board shape using the Fusion 360 sketching tools. However, when I went back to the 2D view I'm unable to move vias and components as there seems to be some DRC violation caused by the new outer dimension. I have attached a small video clip of the problem. How can I resolve the issue?
panpan_fan
Hi @aeies
You can change the push mode to Ignore Violators, then you can move parts freely.
And please fix the DRC error after your movement.
Panpan Fan
aeies
Hi @panpan_fan,
Thank you for your reply. Unfortunately there are no DRC errors. I tried showing it in the recording below but the windows screen recorder doesn't like the DRC pop-up screen. Are you able to recreate the problem? See my workflow in the other video.
panpan_fan
Hi @aeies
Would you mind sending me the file to check?
I will give my email address to you as a private message.
Panpan Fan
panpan_fan
Hi @aeies
Thanks a lot for your file!
I can reproduce this issue and I have reported it to the develop team.
I will keep you updated when we release the fix for this issue.
Panpan Fan
