DRC Errors
DRC Errors
jmorphet
DRC Errors
jmorphet
I was following along with Jorge Garcia's tutorial on PCB Layout. No surprise I ran the DRC check and got some errors. I was able to fix all but the  Board Outline Errors. I don't understand what the errors are. Can anyone help?
jorge_garcia
Hello @jmorphet,
This happens if the convert outline to polygon stays active and the outline is clicked twice. The easiest way to fix this is to delete the polygon and the extra bit you are going to have and then redo the convert to polygon command.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jmorphet
Deleting and remaking the polygon worked. Being new at this, it took a little effort to figure out how to dlete the polygon, but I figured it out.
