Discrepancy in footprint of component in Library and Board file
k.mahuvarkar
k.mahuvarkar
Hello Everyone,
I am using Fusion 360 to make circuits and 2 Layer PCBs.
I tried importing the symbol and footprint of USB C Connector from GCT: USB4056-03-A (Product Link).
Image 1 is the footprint I see within the library; Image 2 is the footprint the software displays on the board file.
Image 1: footprint in libraryImage 1: footprint in library
Image 2: Footprint on Board FileImage 2: Footprint on Board File
The drill size and pad diameter, shape Round for B1 - B12 Vias are 0.4mm(15.74803 mil) and 0.6mm(23.62205 mil)
and Shield points are Long Shade Pad with dimensions Drill: 0.5mm(19.68504 mil) and 0.6mm(23.62205 mil)
When I import this component on my schematic and board, the diameters of the Through Hole Components is increasing. Am I missing a certain setting in the Board File?
Please do help out, facing this issue for the first time.
Thank You in advance.
panpan_fan
Hi @k.mahuvarkar
I hope you are doing well!
It is caused by annular ring setting in DRC.
You can find more in https://www.autodesk.com/products/fusion-360/blog/what-you-didnt-know-about-eagle-restring/
Hope it can help.
Panpan Fan
k.mahuvarkar
Thank You @panpan_fan
This worked out for me.
