Dialog layout is not preserved.
raff.pls
raff.pls
Dialog windows like INSPECTOR or SEECTION FILTER are not preserved in terms of size and position.
Very annoying. How to save the layout?
jorge_garcia
Hello @raff.pls,
I hope you're doing well. I've reported this issue. The layout is supposed to save automatically when closing Fusion 360.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
raff.pls
I have SELECTION FILTER and INSPECTOR in one column on the right. I am reducing the width but it is not preserved on next opening of Fusion360.
SallyYang
Thanks for reporting the issue to us.
Could you please follow my steps below to help us narrow down the issue:
  • Launch a new Fusion session
  • Create an electronics design > create a new schematic > Reset to default layout(see pic below) > Set the panels as your preferred size and layout
  • Create a new PCB > Reset to default layout > Set the panels as your preferred size and layout
  • Do the same operations for electronics library design
  • Close Fusion and launch it again.
Can you see the panels layout preserved?
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
raff.pls
Yes, it works now. Thanks.
SallyYang
Thanks for your confirmation. Please let us know if you see this issue again.
Sally
Sally Yang
Autodesk, Inc.
