Design Rules bug
Design Rules bug
n.smithHJCP5
Design Rules bug
n.smithHJCP5
Trying out the new Design Rule editor in v2.0.20256 x86_64.
I created the following table
Note the bottom right class "51-150V, <15A" in both boxes.
I hit OK to close the Design Rules. I reopen them. Then the window looks like this.
When I hit the drop down, it doesn't even indicate what 2 are selected
Did I do something wrong? I know I selected "Copper Clearance (Different Signals)" and selected the same two signals for both. But I don't think that explains what's happening here.
jorge_garcia
Hello @n.smithHJCP5,
How many netclasses do you have in total?  From the images you can see that there is a checkmark for default. The checkmark lets you know what netclasses are selected. If you have more than 7 netclasses if could be that one of the other netclasses is selected.
You should be able to scroll through the list and find the other checkmark, let me know if you can't scroll. Try unchecking default and see if that shows you what the other netclass is.
I don't think you've done anything wrong, I'll speak to the devs in case the special characters are messing with the rules.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
n.smithHJCP5
All the net classes are shown. I'm fairly certain it was a special characters issue. I changed the name from
"51-150V, <15A"
to
"51-150V under 15A"
and the issue is fixed.
I'm fairly certain what was happening is by having the two similarly named "51-150V, <15A" "51-150V, >15A" Fusion was confusing the two.
panpan_fan
Hi @n.smithHJCP5
I hope you are doing well!
Today we release Fusion V2.0.20754 and this issue should be fixed now.
Please have a try, thanks a lot!
Panpan Fan
