Create non rectangle PCB
dm.pozhidaev
dm.pozhidaev
Hi. I dont found answer for my task.
I want create pcb like on pic . How I can export pcb form from solid design sketch to design board instead rectangle pcb at default? Thanks!pcb.png
yqliu
Hello @dm.pozhidaev , this is pretty easy to do in Fusion Electronics. You can find a "Create 3D PCB" command in the Design environment. Run it:
This will create a 3D PCB document. In this environment, click either "Create 2D PCB" or "Link to 2D PCB", you can get the outline in 2D PCB:
