Command Line Mode
Command Line Mode
VynxZ
Observer Observer
Command Line Mode
VynxZ
Observer
Observer
Hello, Good Day, would like to ask from everyone here with regards to the command line mode in Fusion 360 Electronics. I'm using Autodesk EAGLE for electronics and when I shift to Fusion 360, I'm having a problem about the command line mode, like when I do Ctrl+D it will directly write down "Delete" in Command Line instead of doing the function. Unlike from EAGLE it will directly do the function. Would that be possible in Fusion 360 Electronics like how it works in EAGLE and how should I do it? Thank you very much.
jorge_garcia
Hello @VynxZ,
I hope you're doing well. I'm not able to reproduce this, do you have a recording of the behavior? Just to make sure, the Electronics command line is on the top right. You can enter is by using the / command.
If you can post a recording then I can figure out what's going on.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
