Clearance/ Creepage
Clearance/ Creepage
nurist_m
Clearance/ Creepage
nurist_m
Hello everyone!
on my journey to get used to Fusion electronics I came across a problem and I hope that somebody can help me.
Dealing with boards with different net classes there are regulations that forces you to keep a distance between safety low voltage and for example mains. Usually in Europe you have to keep at least a 5mm distance between low voltage nets (let's say 5V) and mains (230V).
Filling out the 'Clearance Matrix' prevents routing into no go areas and handles clearance pretty well.
But what about creepage?
In real life scenarios I often come across limited board size and regulation demands and usually the solution is to define a milling path in places where to nets come to close to each other.
Generally the creepage distance is dependent on the dielectrics of the used board's material and the voltage.
Air shows higher resistance to creepage currents than for example FR4 material.
Is it possible to handle creepage distances with Fusion, especially in relation with multi layer boards where traces of middle layers might be too close to top or bottom layers.
jorge_garcia
Hi @nurist_m,
I hope you're doing well. So it's possible, but you have to take care of these things manually. You will draw in the slots on the milling layer and you'll make sure not to route anything through them.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
nurist_m
Hey @jorge_garcia ! Thank you for the answer.
Your suggestion is the obvious manual approach but I was thinking of a more automated solution.
The goal is not to add any slots where it's not needed. Or getting an error during DRC when slot length is not sufficient.
However, your suggestion is appreciated
