Changing Origin Size in Fusion EDA Schematics
nsbernar
nsbernar
I have this library part https://www.snapeda.com/parts/EXB-D10C221J/Panasonic/view-part/?ref=digikey&welcome=home
But when I use it, the origin is either too small to show up or just is missing (see attached screenshot). You can see where the origin is in the library, but it's just basically missing from the schematic part. Any thoughts?
silvio3105
Looks fine for me.
Origin is between 3 and 9
Turn on layer for origins(no 23).
nsbernar
As I noted, you can see it in the library editor. Have you tried placing the symbol?
silvio3105
No, I'm not.
Check layer number 23. If it's off in schematic, then you cannot see origin and move component.
It should be on same spot where's in the lib(device).
yiqiu.han
Hi, @silvio3105
The 3rd party libraries you mentioned come from SnapEDA, they are not authorized by Autodesk. You could reach their website for more information.
Yiqiu
nsbernar
Thank you, I find that most of these are created by software and responses are few and far between regarding any issues with them. Thanks for your reply.
