Can't move certain packages in some directions
I spent several hours laying out a 3D rendering of a circuit board and I often found that I couldn't move an image into a correct orientation. It often happened with connectors. For example, a 5 pin socket would move side to side and front to back, but it remains hovering above the board because I can't move it down. An M12 8 pin connector is at a 90 degree angle to the board and I can't find a way to rotate it into the correct orientation and an SD card socket can only be placed on a board upside down.
I did all this by bringing my board from Eagle into Fusion 360, then I edited the board, then got the list of components. I would right click on the component and do "replace body" and I would then select a STEP file. It all works, except I'm limited in how I can orient the component. Is there a way around this?
