@benjamin.jordan wrote:
Hi @scottmoyse while @jorge_garcia 's answer is certainly the correct and thorough one, I thought I'd add something simple in case all you wanted to do was relocate everything in unison in the PCB editor so that the first row of switches is on grid.
You can select EVERYTHING using CTRL+A in the PCB editor. This will also select the lines that define the PCB outline.
You can click the MOVE icon on the PCB editor DESIGN ribbon.
Then Right-click on the center of the first switch's hole (as close as you can) and click "Move: Group" from the popup menu.
Then when you move the mouse to the grid point desired and left click to complete the move.
@benjamin.jordan so... it appears as though as soon as a change occurs to the model, which impacts the 3D PCB size and position, it just resets the location of the PCB outline in the 2D PCB document. Which in turn stuffs up the alignment of the switches relative to the PCB.
Combined with my desire to have functional models of my switches, this alignment issue seems to be a significant limitation. Since it appears the only way I can get the position of the 2D components to remain associative with the 3D position in the 3D document is to include the model in the component library, then move the component into place in the Design Workspace. I could do this of course, but then I can't have switch motion in my digital prototype.
It's a shame that we can't define a PCB origin in the 3D PCB document. Then we could replicate the AutoCAD to Eagle workflow shown in this series of videos. https://www.youtube.com/watch?v=BBNY-Ca9JhQ
At this point I'm not sure at all what the best course of action is. It seems this integration isn't really ready for the parametric CAD world just yet and is more of a bottom up workflow then a top down one.
Would you be open to discussing this on a call? We have a trade show in a few weeks here in New Zealand and it would be great to be able to show off this workflow.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
