CAM Preview Does Not Show Component Values
There is a topic about "3D PCB Does Not Show Component Values"
https://forums.autodesk.com/t5/fusion-electronics/3d-pcb-does-not-show-component-values/td-p/9721639
Response From Autodesk (in 2020) was "The values are not showing on 3D PCB on purpose to make the board clean. We will consider to add an option to show the values in future release."
But, why even CAM preview not showing Values, after selecting value...?
It's more necessary to check quickly how does the board looks like after manufacturing...
But I have to export Gerber file and upload it on online "gerber viewer" tool to check the actual preview...
So, In another view Fusion CAM preview is useless...!!
Also, tried many ways to set my edited "CAM job file" as default, but failed in Eagle and Fusion also,
There always default template set after restart...
(only custom CAM set default in selected project on Fusion)
jorge_garcia
Hello @Anonymous,
Thank you for for posting, the CAM preview function is very simple. It has a hard coded set of layers that it follows. I'll make an enhancement request for this, for it to follow the default CAM job.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Thanks for reply.
I hope this issue will resolved soon...
