Bug - Unconnected via not detected inside polygon pour.
maxime_drouguet
maxime_drouguet
Community Visitor
Community Visitor
On the straightforward design shown here below, the three resistors are supposed to be connected to the ground polygon on bottom layer through vias. When I draw a polygon pour encompassing one of those vias, Fusion still considers that the via is electrically connected to the ground: No unrouted line to that via nor any warning/error in the DRC...
Is it a bug or have I done something wrong ?
(Fusion 2704.1.53 x86_64)
nnovotney
Poly Pour on what layer? (verify its layer, and the net name of the pour, right click on its properties)
click here to ensure bottom is showing priority
jorge_garcia
Hi @maxime_drouguet ,
I hope you're doing well. In addition to what @nnovotney , mentioned a new version of Fusion was released this week. Could you update and see if you get the airwire?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jorge_garcia
I hope you're doing well. I was able to reproduce this behavior, I believe it's fixed for the next release of Fusion but I'm going to get confirmation.
Best Regards,
Jorge Garcia
nnovotney
Gee, if true, that is really pathetic testing from the whizzes at Autocad.  This could cause some serious blunders.
Yet, they detect/declare text clearance collisions to copper where there aren't any.  A lousy implementation--maybe start over.
maxime_drouguet
Community Visitor
Community Visitor
Hi @jorge_garcia ,
Thank you for your attention. Please let me know as soon as the bug is fixed !
Best regards
jorge_garcia
Hey @maxime_drouguet ,
The fix will be in the October release at the latest. You can use the insider version to get access to the fix sooner.
Best Regards,
Jorge Garcia
