Message 1 of 1
Bug or Expected? - Via behaviour when moving trace segment between layers
In the attached video:
Put down two vias on either side of a resistor, tracks to each of the vias.
If I delete either track, the corresponding via stays.
If I select the track and change it's layer from Top to Bottom, the associated via vanishes.
If I "lock" the via, delete the track the via stays
If I then select the track and change it's layer, the via again disappears even though it's locked.
Not sure why deleting a track segment allows the via to stay, yet moving the segment to another layer causes the via to disappear?
I would have expected that the lock should have saved the via at least.
Bug or expected?
BR,
-- Glenn
