Bug in thermals?
Probably I discovered a bug. It didn't appear month ago when I created previous version of project, based on the same components. Please take look at GND signals routed from polygon.
On the first image - connection is broken. I tried to determine the reason. For test purpose single path, adjacent to GND route was removed - it didn't help. When second path was removed - GND signal appeared automatically - please refer #2. On the 3rd approach thermals on polygon were disabled. GND signal is properly connected. Obviously I want to use thermals.
Situation is related to small pitch numbers. In this case ATmega128 is used (pitch 0.8mm). I discovered rule when thermals will connect polygon and pad. The thermal isolation in DRC must be at least 2 times lower than thermal width set on the polygon.
In previous project these values were set to 10 mils both and everything was ok. The consequence is extremely small thermal isolation - sometimes difficult to achieve in final PCB.
Is it possible to brake above size dependency and force somehow GND connections from Polygon to small pads?
