Board: Layers can no longer be switched on and off
infoJFAS4
infoJFAS4
Hello everyone,
since the last update (with the introduction of dark mode) the tab in which the individual layers can be switched on or off is missing.
The layer button also has no function.
How can I access the layer list again?
Sheet: The (redesigned) Layer tab is available here.
Greetings Peter
CGBenner
@RichardHammerl
Richard, is this a known issue, or can you help here?  Thanks!
Chris Benner
jorge_garcia
Hi @infoJFAS4,
I hope you're doing well. If you switch to the normal Fusion theme does the display panel return?
We are not seeing any other reports of this. Another thing to check is to go to View > Restore Default Layout.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
infoJFAS4
Hello Jorge,
thank you very much. This was the solution. Simple but effective.
Greetings Peter
