Bad UX - object selection
silvio3105
silvio3105
I think I've already open topic about this problem/bug.
So, in this video I selected layer tPlace. I want to select object(line) in tPlace layer. For some reason Fusion does not select line. Because of something.
Why Fusion does not prioritize object in current layer?
Also, if I want to deselect object, i have to click twice.
https://youtu.be/k3aAg2cO6sU
silvio3105
Here's another video. I'm trying to select line in tPlace layer and move it.
https://youtu.be/RANbpkS-j-0
Fusion, at least electronics module, has really "retarded" UX. I know UX is copied from EAGLE but come on!
Don't reinvent the wheel, don't discover warm water, just copy basic UX things from other SWs.
It's like you enter in car and you see clutch on right side, you give throtthle with steering the wheel etc...
Quality of Life releases should fix UX bugs. Quality of Nerves should fix crashes etc. 😄
jorge_garcia
Hi @silvio3105 ,
Thanks for sharing this one. Like you I would expect the active layer to have priority in the selection, from what I remember its a little more subtle than that but it doesn't seem to be working correctly to me.
@panpan_fan Could this be reported and investigated by QA? Thank you in advanced for logging it.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
panpan_fan
Hi @silvio3105
For object selection, you can use the selection filter to select the object you want easily.
By the way, when you try to move objects which are overlapped, you can also follow the guidance message to select successfully
Panpan Fan
silvio3105
"For object selection, you can use the selection filter to select the object you want easily."
Yes, I know for selection filter and it does not make selecting objects easy.
"you can also follow the guidance message to select successfully"
I know for left-right mouse click thing. Check video from second post and you will see the problem.
Sometimes I have the feeling that only "work-a-round" is posted(like Panpan's post) and that is it. I hope those UX/controls will get fixed. Use solution from AutoCAD for overlapping objects. It's software from AD, same house that released Fusion! C'mon!
