Autorouter slow
Autorouter slow
Packmers_
Autorouter slow
Packmers_
Hi
did someone try the Autorouter after the last update?
It's very slow, for a 100x160 Card with 6 Layers and 320 Wires it needs 6 hours to arrive to 100% and other 4 hours to optimize 2.
Has anyone an solution ( I've routed the same board two years ago without problems)
Wolfgang
jorge_garcia
Hello @Packmers_,
I hope you're doing well. The TopRouter algorithm is much slower than the old brute force algorithm. If you want a quick result then uncheck the TopRouter variant checkbox in the Autorouter setup dialog.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
HelenChen-ElectronicsQA
Hi @Packmers_ ,
So sorry to hear that you're having trouble.
Could you please try below options one by one and see which will help? If the option 1 doesn't work, please try option 2.
Option 1: Uncheck "Enable GPU rendering"
 1) Close Electronics design files firstly.
2) Go to Preferences dialog > General > Electronics > Misc > Uncheck the checkbox of "Enable GPU rendering" > Apply > OK.
3) Then reopen the Electronics design files to have a try to see whether still have problem.
Option 2: Uncheck High-resolution canvas graphics on high DPI displays.
1) Close all Electronics design files
2) Go to Preferences > Graphics > Display > Uncheck High-resolution canvas graphics on high DPI displays > Apply > OK
3) Close Fusion and relaunch it to have a try again.
Hope they could help and looking forward to your feedback.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Packmers_
Hi Helen & Jorge
it didn't help.
Unfortunly it's an old design, so maybe any differce may be.
There are only 3 Routes running without TopRouter, the cpu load is around 30% Memory 40%.
I will try soon if it's the same problem with an new design too.
If someone else finds the same effect, please give a reply.
Do you have a design where you could benchmark the autorouter?
Kind regards
Wolfgang
jorge_garcia
Hello @Packmers_ ,
I hope you're doing well. If you want to share the design that might help us figure out what could be going on.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
