Are we ever going to see actual drawing support?
We're coming up on 2 years of electronics being included in fusion and there is still virtually zero drawing support.
My group is at the point that we're trying to get documentation in place to submit to board shops, and trying to make any kind of fab drawing is nearly impossible. You can start a drawing from the 3d board file, but it won't show all the items you need. The rendered soldermask doesn't show the actual cutouts (Which is a bug in general), so you're left to decide if you want to just show copper, or only through holes. The silkscreen layer just doesn't show in the drawings at all. There is zero support for adding drill tables, I've had to run the ULP in the layout window, print that to it's own PDF, and then insert it into the finished drawing PDF with a separate tool. Same with a BOM, my options are manually create the table in the drawing, which is painful, or output the BOM from the manufacturing processor and just make it it's own document.
I realize that most information can be captured through the manufacturing processor outputs, but there is still information that is easiest shared through a drawing when trying to submit to a shop. The fact that I can't even get an accurate rendering of the board in a drawing is astonishing.
Will there ever be actual drawing support?
