ALERT!! DO NOT CONFIGURE 3D PACKAGES IN ELECTRONICS LIBRARIES
jorge_garcia
Autodesk Autodesk
jorge_garcia
Hello everyone,
Just want to give a heads up from the developers. For now Fusion configurations are not supported in the Electronics library and using them will create problems with the 3D packages requiring you to recreate the packages for any that have configurations.
So TL;DR; Don't use configurations in the Electronics library.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
silvio3105
When fix will be available?
harald_hoopmann
Is it also impossible to edit footprints in a open library? I've tried it on several components, but without succsess. I can only edit the symbols.
Pieter.Jan.Van.de.Maele
@harald_hoopmann could you explain the steps you were taking? That should be working fine but maybe something is going wrong somewhere.
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
