Add Component Interface
ryan.brewer9R5KC
ryan.brewer9R5KC
When adding parts to a schematic, is there a way to configure the menu so that instead of having to search through a list of every component in every library, it is set up like Eagle where you select the appropriate library and find the desired component? The new method is slower and far more cluttered, not sure why it needed to be "fixed" to begin with...
jorge_garcia
Hi @ryan.brewer9R5KC,
I hope you're doing well. See the image, you can set the panel to just a specific library or to the libs already used in the design. The main limitation that needed to be fixed was the inflexible search algorithm that required the use of placeholders.
Let me know if you have any other questions
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
ryan.brewer9R5KC
Got it, didn't realize that - thank you.
