3D PCB white because of silkscreen
0987941
0987941
Hello everyone,
I’ve encountered an interesting issue in my most recent design. When I enable the silkscreen layers, my entire 3D PCB turns completely white. This happens on both the top and bottom sides of the PCB.
This is the first time I’ve experienced this in a project. Does anyone know how to resolve this issue?
Kind regards,
Jordy
panpan_fan
Hi @0987941
I hope you are doing well!
Thanks a lot for reporting this issue to us.
Would you mind sharing your file to us?
I will send you a private message.
Thanks a lot!
Panpan Fan
Hello @panpan_fan
Thank you for yout help, I have sent you the f3z file.
panpan_fan
Hi @0987941
Thanks for your sharing!
As I reply in the email, you can delete the duplicated dimension circle under component MP3 as a workaround.
You can have try, thanks!
Panpan Fan
Hi @panpan_fan,
Yes that worked. Having removed that small extra board outline outside of the main board outline it all worked as it should again!
Thank you for your help!
Kind regards,
Jordy
r.kreczewski
Hi @panpan_fan,
Could you explain what was the main reason of this issue? I have this issue with my projects, all projects :).
