3D PCB View Help
3D PCB View Help
dwhiteley83YBM
3D PCB View Help
dwhiteley83YBM
Hi All,
I'm having an issue on surface mount components, if i connect any surface mount pad to a copper pour - it doesn't connect in 3d view and acts as a separate entity. Making it difficult to easily cnc from the 3d pcb view.
If you see the attached image, a through hole part connects just fine via the thermals, but a surface mount doesn't.
I've even checked an old design that works correctly, if i press "Re-Fill polygon pours" it now has the same issue.
Has something changed that i'm not aware of? I'm no expert but any help would be greatly appreciated
yiqiu.han
Hi, @dwhiteley83YBM
Our develop team is working to fix this issue. We will try our best to fix it ASAP.
By the way, you can use the rectangle polygon in the footprint to have a try.
The rectangle polygon should covers the pad completely.
Please have a try, thanks!
-Yiqiu
