Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
When creating cabinet drawings, is it possible to print the size and machining program for each piece at once?
1 REPLY 1
ehdtjs0408
90 Views, 1 Reply
hello.
With the cabinet assembly drawing drawn, is it possible to output the size and information of each piece composing one cabinet in CSV file format?
And is it possible to output the cam file by running the post-processor at once in the assembly drawing?
I am using a Biesse Rover machine. A post-processor capable of outputting in CIX format has been found and is being used.
When assembling a cabinet and printing it, I want to print the cam files for all pieces in one cabinet drawing at once, rather than specifying posts individually.
Thank you
Tags (3)
1 REPLY 1
dan.banach
in reply to: ehdtjs0408
Hi @ehdtjs0408
Thanks for posting your question. Fusion 360 BOM currently can't export size information. But there are third party Add-in for Fusion 360 called OpenBOM. Here is a video that Product Design Online created.
Another Add-in to look at is Size to Parts List.
I'm not aware of a way to create a POST file from a drawing.
@kellings Do you have any other ideas?
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
