Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
What is the best way to 2d pocket this project?
1 REPLY 1
mikeSHNJV
92 Views, 1 Reply
I am looking to pocket out this area in stone. For some reason, when I use just the standard 2d pocket function, it gives me errors.
Any idea?
Mike
1 REPLY 1
kellings
in reply to: mikeSHNJV
Hi @mikeSHNJV Your file or screen shot doesn't appear to have been attached. Can you try again?
How close is the tool diameter to the pocket size? A common issue is found on the linking tab called Helical Ramp Diameter. When the tool and pocket are somewhat close to the same size, a helical ramp diameter that is too large will often prevent the toolpath from generating.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
