Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
What is pin slot as a pocket?
1 REPLY 1
jimi_hunter008
75 Views, 1 Reply
I am trying to understand a pin slot feature but there is a statement that describe the pin slot as a pocket whose boundary is two parallel edges connected with half circles.
1 REPLY 1
kellings
in reply to: jimi_hunter008
Hi @jimi_hunter008 I pulled up some documentation for you that may explain this better than I can with words
Fusion 360 Help | Joint types | Autodesk (look for the pin slot definition there)
There is an animated example of pin slot on the following page
Fusion 360 Help | Create a joint | Autodesk
Let me know if that helps to provide some clarification or not.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
