Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
WebGL disabled
1 REPLY 1
misdaboatXT7KV
100 Views, 1 Reply
WebGL disabled
Found an issue selecting and editing tools for new toolpath in fusion 360
after a July F360 update.  was off for the summer, ran into this getting classes
ready for the fall semester. see WebGL.png for details of the problem.
you could not select any tooling within the fine line red border.
Found the FIX on Autodesk Help.... see attached pdf.
to resolve this issue in my lab I had to Disable Tool Library - 3D Preview in Preview Features
hope this can be helpful to anyone experiencing the same issue
Mike Cannon
Pensacola State College
Program Coordinator / Instructor
Mechanical Design & Fabrication A.S.
1 REPLY 1
kellings
in reply to: misdaboatXT7KV
Hi @misdaboatXT7KV Glad you found a solution. If you update the graphics driver from the manufacturer's website (and not from Windows update) that should resolve the issue as well and you can leave the 3D preview on. I have a feeling there will be some future things where you will want to make use of this option.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
