Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Using If statements and Logic operator for cutting patterns
1 REPLY 1
jonathanYY8UL
92 Views, 1 Reply
Hi all,
I'm trying to use an If statement in my parameters to cut a hole in an object. Basically what I want to happen is If my length is 0-1" I don't want to cut a hole, If the length is 1-2" I want to cut 1 hole. Is there a way to have an extrusion not happen in an IF statement, essentially making my instances of an extrusion/pattern 0?
1 REPLY 1
kellings
in reply to: jonathanYY8UL
Hi @jonathanYY8UL This isn't currently possible. However, there is some future functionality that should accomplish what you are trying to do. I can't speak with specifics on unreleased features.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
