Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Using form tools on a solid object that was made from several bodies
3 REPLIES 3
crchisholm
125 Views, 3 Replies
Not a clue what I am doing with the form tool.  I put together a solid object to use as a base model with the intension of using form tools to do the finish shaping.  Apparently, things are a bit more complicated than I thought.  I can't seem to do anything with the mode (fillet, camfer, or form).  I sometimes get the message that the model is not manifold. Not sure how to make it so, or to get the form tools to recognize the mode.
I've attached the document and a screen shot.  Can anyone get me a kick start in the way of a tutorial or docuement that might lead me toward this goal?
3 REPLIES 3
kellings
in reply to: crchisholm
Hi @crchisholm Does this video provide any help?
(2) Fusion 360 - BRep to T-SPline workflow - YouTube
I had a look at your file and I'm not sure you are going to be able to do what you want based on the file you have constructed. One thing that would help would be to have all bodies joined as you create them. I'm not sure the geometry you have in the file will be clean enough to bel about to use the forms tool on.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Marco.Takx
Hi @crchisholm,
Unfortunately, I don't understand what your goal is.
If it is to make some shape on the edges, you can maybe create a sweep of a contour along the edges.
But without knowing what your goal is it is hard to help you further.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Consultant
crchisholm
in reply to: kellings
I guess I should have lead off with the ultimate goal.  Short version:  I'm retired and on SS and am looking for a way to make reliefs from solids.  The idea behind the orchid model was to try and create relief of the orchid without breaking the bank.  I know that I can do it with Aspire and other high end software solutions, but I really can't afford their price tag.  Sooooo....being the cheap skate that I am, I'm trying to find a more affordable way to do this for someone on SS.
Charlie
You've got Fusion.
