Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Unable to Sign into Fusion 360.
3 REPLIES 3
tolgakasss
106 Views, 3 Replies
Hi I am having having this issue as well. I was wondering could my account please be reset? Thanks.
[Admin moved message to its own post]
3 REPLIES 3
dan.banach
in reply to: tolgakasss
Hi @tolgakasss
I invited you to my Educator's Team - Des 101 Project. Can you please open the invitation email and click Join Team.
Then in Fusion's Data Panel you should then be able to Create your own team.
  1. Show Fusion's Data Panel.
  2. Click on the Fusion Team Switcher - drop down arrow.
Click on "Create or join a team"
If you're not prompted to create a Fusion Team, do the following.
  1. Navigate to login.autodesk360.com.
  2. Sign in.
  3. You should be prompted create a team hub.
  4. Close and restart Fusion.
Please let me know if you are then able to sign into Fusion and then create \your own Fusion Team / Hub
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
Hi @tolgakasss
For testing purposes, I removed you from my Educator's Team. Can you please run Fusion 360 from a browser (Chrome is preferred) by going to https://fusion.online.autodesk.com and sign in with your Autodesk Education ID (same email that you log into Fusion 360 with) and see if you are prompted to create your own Team.
Please keep us posted.
-Dan
Dan Banach
dan.banach
Hi @tolgakasss
I wanted to check in and see if you were able to create your own Fusion Team please.
Please let us know your status.
-Dan
Dan Banach
You've got Fusion.
