Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Unable to select to extrude
2 REPLIES 2
laurie_dale
97 Views, 2 Replies
Hi there, I am pretty new, so I apologize if this is a simple fix. I am trying to extrude from the drawing I added to the left of the box in thecircle.  I did check that the drawing was closed.  Any suggestions are greatly appreciated.Screenshot 2023-08-31 082737.png.
2 REPLIES 2
kellings
in reply to: laurie_dale
Hi @laurie_dale In your image, the lines shown are dashed. That means they are construction lines. Construction lines are ignored for solid modeling operations. You can't extrude them, you can't revolve them, you can't sweep them, etc.
If you right click on that sketch and choose edit sketch, you can then select those sketch entities and in the sketch palette (on the right of the screen usualy) you will see a line type option. Once you have the sketch entities selected, click the construction line type button to deselect it and turn the sketch geometry into solid lines. Then you should be able to create your extrude.
If you have any issues, please let us know and we'll see what the next step are.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
kellings
Hi @laurie_dale Were you able to get this issue resolved?
thanks,
Kevin
Kevin Ellingson
You've got Fusion.
