Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
UNABLE TO POST 4 AND 5 AXIS PROGRAMS
1 REPLY 1
darron.lanier
75 Views, 1 Reply
Fusion will not let us post any 4 or 5 axis programs. It tells all my students these options need to be unlocked. Does the education side have these capabilities or what would be the solution.
1 REPLY 1
dan.banach
in reply to: darron.lanier
Hi @darron.lanier
The 4 and 5 axis functionality is now in the Machining Extension. Autodesk Education accounts get access to the Extensions for free.
Educations accounts can access the Extensions for free by doing the following:
  1. On the top-right side of the screen click Extensions
  1. In the Extension Manager dialog box, click on the desired Extension
  1. Click on Start Access
Note: The Extension will need to be renewed every 30 days (follow the same process).
Let us know if this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
