Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Unable to convert solid object to sheet metal
1 REPLY 1
lo_kin
74 Views, 1 Reply
When I'm trying to convert an object into a sheet metal so I can unfold it and add patterns to it, the software returns a "can't calculate body thickness" error. Any advice on why this error shows up? I tried it on a simpler geometry before in the same file and it worked. Maybe because of an existing sheet metal rule?
Thanks in advance for the help.
1 REPLY 1
dan.banach
in reply to: lo_kin
Hi @lo_kin ,
Thanks for posting your question. Looking at the image, I believe this issue is the thickness does not look uniform. Sheet meet requires a consistent thickness. You could try to split the bodies into two bodies with a uniform thickness for each body and work with them independently.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
