Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Unable to complete update
4 REPLIES 4
howatt4
127 Views, 4 Replies
Does anyone else find that with using the --process update method, the installer never stops running?
4 REPLIES 4
dan.banach
in reply to: howatt4
Hi @howatt4
Thanks for the post. You can stop the Streamer services that are running. The Streamer should only be used for install or update. The team is looking into this issue.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
howatt4
Thanks @dan.banach! The problem is, I'm pushing it out to a lab, and I can't ask the school tech to go log into all of the machines to close streamer.
dan.banach
Hi @howatt4
Thanks for the clarification. When the computer is restarted, does the streamer still run?
On a related topic. The next update to Fusion is tentatively planned for Monday Jan. 30th in the evening (pacific time).
-Dan
Dan Banach
howatt4
in reply to: dan.banach
OK, thanks for the notice! I'll check and see.
You've got Fusion.
