Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Trying to use the Basic Training Samples in the Data Panel
8 REPLIES 8
Message 1 of 9
sangerasong
292 Views, 8 Replies
Howdy Folks,
Where are the Hands-on exercises that match the "Basic Training" Samples listed in the data panel of Fusion 360? They are not related to the Self-paced Learning found here:
https://help.autodesk.com/view/fusion360/ENU/courses/
I want myself and students to work these files shown below.
8 REPLIES 8
Message 2 of 9
kellings
in reply to: sangerasong
Hi @sangerasong Are you saying that when you click the folders listed in your image, there aren't any files located in those folders? I just checked some of them and I was able to see files as shown in the example screen shot from 02 - Basic Sketching
Do you see any files in any of the projects listed under samples? Like in the CAM samples as an example?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 9
kellings
in reply to: kellings
@sangerasong Just checking in to see if you had any further progress with your issue from my questions above.
Kevin
Kevin Ellingson
Message 4 of 9
sangerasong
I see the files. My question is Where are the tutorials associated with them located?
Message 5 of 9
sangerasong
To be clear -- I see all of those files. I'm just wondering which "tutorials" to they belong too? It's not the Self-paced tutorials you can find in the Help menu.
Message 6 of 9
dan.banach
Hi @sangerasong
I believe the files are for the tutorials that are linked in the Help menu.
Some of the tutorial may have been removed because they are out of date, but the dataset file still exist.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
Message 7 of 9
sangerasong
in reply to: dan.banach
@dan.banach @kellings  Nope. Those files are not associated with the Help Menu. That's my frustration. Where are the "Basic Training" tutorials.
Message 8 of 9
dan.banach
Hi @sangerasong
 The only other tutorials that I'm aware of are in Fusion's Help system
Hope this helps.
-Dan
Dan Banach
Message 9 of 9
sangerasong
If those sample aren't connected to an actual "Hands-on exercise in your Help topics" that title is misleading and confusing. Fix it or get rid of it would be my suggestion. Then we can "close" this topic 🙂
You've got Fusion.
