Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Trouble saving files
3 REPLIES 3
rstehlik_12
129 Views, 3 Replies
I have had a couple students that get error messages when they try to save a file. It simply says "Cannot be saved"
I verified that the computer was connected to the internet. Is there any other reason this might be happening?
When trying to open the file in question, they get the following message:
It's pretty disconcerting to not be able to save your work. If this happens again, are there any workarounds?
Rob
3 REPLIES 3
dan.banach
in reply to: rstehlik_12
@rstehlik_12
Sounds like the Cup file is referenced into the assembly and the Cup file had an issue when uploading. Please try the following:
  1. In the Data Panel, expand the versions of the Cup file.
  2. Click the 3 dots to the right of a previous version and click Open from the menu.
  3. Then under the File menu click Save As Latest. This will create a new version.
  4. Open the assembly file, and see if you can save the assembly.
If this doesn't work try the following:
  1. Open the the assembly.
  2. Right-click on the referenced Cup file and click Break Link.
  3. Save the file.
Keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
rstehlik_12
in reply to: dan.banach
Hi Dan,
It's not an assembly file, but I will try opening a previous version and saving it as the latest.
Rob
dan.banach
Hi @rstehlik_12
Were you able to promote a previous version and then save the file?
-Dan
Dan Banach
You've got Fusion.
